New from SMS GreenStuffWorld 1mm Drill Bits x5
GreenStuffWorld 1mm Drill Bits x5​
This GreenStuffWorld pack contains five 1mm drill bits for drilling, positioning and starting holes in a variety of materials used in hobby projects. With all five bits supplied in the same diameter, the pack provides a useful supply for modelling work that calls for repeated 1mm drilling.
The bits are suitable for tasks including miniature conversions, miniature assembly, scale modelling, model railways and arts and crafts. They can be used for creating holes as well as positioning and starting holes during construction and modification work.
Five 1mm drill bits​
Each bit in the pack has a 1mm diameter, rather than an assortment of different sizes. This makes the pack particularly straightforward when you regularly need the same drilling diameter across several components or projects.
The bits are designed for drilling a variety of materials encountered in hobby work. Their uses range from preparing holes during miniature assembly to drilling parts as part of conversions and other modelling tasks.
Compatible with hobby hand drills​
These 1mm bits are compatible with the GreenStuffWorld Hand Drill and hobby drills for small sizes. They can be kept alongside other drills and drill bits to provide a dedicated 1mm option whenever that diameter is required.
For miniature conversions, the bits can be used when drilling forms part of modifying or positioning components. During miniature assembly, they provide a practical size for drilling and starting holes, while scale modelling, model railway projects and arts and crafts provide further applications.
The GreenStuffWorld pack contains five 1mm drill bits, all supplied at the same diameter. Designed for drilling, positioning and starting holes, they provide a dedicated set for repeated 1mm drilling across a range of hobby and modelling projects.
The post GreenStuffWorld 1mm Drill Bits x5 appeared first on Scale Model Shop.
