New from SMS GreenStuffWorld Hobby Hand Drill with 10 Drill Bits
GreenStuffWorld Hobby Hand Drill with 10 Drill Bits​
The GreenStuffWorld Hobby Hand Drill is a compact pin vice designed for precision drilling and tapping when working with models, miniatures and other small hobby projects. Its pen-like shape provides controlled one-handed use, while the swivel head helps with comfortable positioning and accurate drilling in confined areas.
Made from lightweight aluminium, the hand drill has a clamping range of 0.3-3.2mm. Its freewheeling head allows the drill bit to rotate smoothly as the tool is turned, giving you greater control than a larger powered drill when creating small holes and perforations.
For plastic, resin, wood and metal​
The pin vise can be used for precision drilling in plastic, resin, wood and metal. This makes it particularly useful for scale modelling and miniature work where components may need drilling during assembly, modification or conversion.
Its compact design also helps when working in areas that are difficult to reach with larger drilling equipment. The combination of manual control and a small working size allows holes to be positioned carefully without relying on the speed of a powered drill.
Includes 10 drill bits​
Along with the hand drill, the set contains 10 drill bits in three sizes:
  • 5 x 1mm drill bits
  • 3 x 1.5mm drill bits
  • 2 x 2mm drill bits
The 0.3-3.2mm clamping range also allows the hand drill to accept other suitable small drill bits within that range. It can be used alongside other drills and drill bits when different drilling diameters are required for a project.
When drilling, the material should be securely clamped or held in place to prevent movement or slipping. Safety goggles and gloves should be worn during use.
The GreenStuffWorld Hobby Hand Drill combines an aluminium pin vise with a swivel freewheeling head, 0.3-3.2mm clamping range and 10 supplied drill bits, providing controlled manual drilling for detailed work on models, miniatures and other small projects.
The post GreenStuffWorld Hobby Hand Drill with 10 Drill Bits appeared first on Scale Model Shop.
