I hear you! ...checks bank balance...!
True Laurie, but it's not just a case of screwing on a new nozzle and changing the needle. Surely the needle packing would also have to be changed to accommodate a different needle size, and that's a fiddly job! On my Eclipse it's a very small Teflon screw thingy.\ said:Actually to calrify a clarify. Many of the Iwata brushes have alternatives. For instance the brushes I have the HP BH has a .2 needle/nozzle but a .3 is an optional extra. The HP BS has a .35 but can take a .5. Laurie
\ said:I hear you! ...checks bank balance...!
Probably different with each Iwata type Steve. They do produce very nice airbrushes but they are not easy to maintain. Think if you are going to change sizes of needle nozzle regularly the front assembly is the best bet which makes it then easy but more expensive. For me I do not swap as I get used to one and that is it.\ said:True Laurie, but it's not just a case of screwing on a new nozzle and changing the needle. Surely the needle packing would also have to be changed to accommodate a different needle size, and that's a fiddly job! On my Eclipse it's a very small Teflon screw thingy.They are not designed to be easily interchangeable. Many airbrush users wouldn't know how to do it and I wouldn't advise it.
Like it John. Another Scale Model Forum success story.\ said:Right! Had an epiphany today with the freebie airbrush that came with my compressor. Using Vallejo's green primer, I've primed a fair bit of my Churchill today, really sweet surface, almost no fall-out (Aerosols make sure that at least a 3 foot area around the model get primed as well!). I am now sold on dual action - thanks gents, you've saved me from buying single action, then realising I actually need a dual…!However, I don't trust this Airbrush, in the respect that I want to understand all it's foibles - I am the kind of bloke that wants his painting tools as clean as a cat's…well, you know, so I am going to buy an H&S as soon as me pension comes through. Then an extracting booth, then……..
