hi ... looking for detail of the following: heinkel he111 h-22 1./kg53 ..... the serial numbers on the side are GA (werksnummer 3107) .... did this aircraft exist at all and if it did does anyone have a little bit of it's history. tx a lot Lindsey
That makes logistical sense as they were launching V-1s. I'll look them up this evening.\ said:All the info i see regarding 5K+GA are for when they were based at Gilze-Rijen in Holland
If the underside was blue (RLM65) then the codes would have been on the underside of the wings,either GA on one wing and 5K on the other,or just the aircraft letter G on both wings outboard of the balkenkreuz. If the underside was black they'd have been overpainted.\ said:I will look this evening to see if the codes for the undersides are there ....
