Plodding on with the tray assembly, but it's not quite finished yet. (Photo att)
Reading ahead in the instructions it appears that the Robbe battery for this sub just sort of hangs in the hole from a couple of fittings which slide into the battery slots. I think the battery is a bit expensive and I want to use my own batteries which are then interchangeable if one goes flat. I generally use Titan sealed lead acid batts 6v 4ah - they give me quite a good running time - I was thinking about making a box or cradle for the Titan batt out of scrap to hang inside the battery hole - or maybe even just lay the battery on the tray above the hole secured with Velcro ( maybe glue a couple of bits of scrap across the hole to prevent any accidents) - or would this be top heavy? Any advice or suggestions would be really appreciated.
Ian
Ian
