I’ve sprayed the first few coats of blue on to my model car I’ve been working on and really happy with the results. Today, I’ve masked off areas and spray painted some black detailing/car markings. I’ve just removed some of the masking tape and there’s some bits of black overspray and areas where the black has over run a little bit. When the paints fully dry, will wet sanding remove the overspray black and keep the blue underneath?
Also, should you wait until the paint is completely cured before removing the masking tape?
Any help is greatly appreciated!
Thanks
Jez
Thanks
Jez
