Homemade Spray Booth
Create build Bart, looks superb and if it works then it works, why spend more than you have to. Nice, like it a lot.
Si:)
A tip which may be of use Bart. I line the floor and sides with white blotting paper. Easy to keep clean absorbs paint immediately etc and provides a reflective finish which helps when spraying.
@Laurie: thanks for tips. I didn't even think about the not using the filter, but it makes sense. About the paper.. I'd like to paint it inside with white appliance paint, so it will be glossy and easy to clean like a fridge or something.
@eddiesolo: Thanks. I actually spent a bit too much. It still is imo much better construction than cheaper expo. Of course it will be upgraded in the meantime:)
