Thank you. Wow I am about to cry he is to good. I am planning on trying it on some test models. Have you used this tip? If was how did you get on?\ said:Here you go, well worth a watch, as are all te build videos on this channel.This ones a Tamiya Sherman and 2 episodes.
The bit you need is 6:59 in (approx)
YouTube - Tamiya M4 Sherman Tutorial 1/2 ep19
Hi\ said:I have seen others use stretched sprue, lightly clued in place and then softened with plastic weld, thin CA super-glue or cellulose-thinners. The weld lines were then shaped using pins, knives, the dull end of drill bits and embroidering tools. This is the method I'm planning to try out when I get around to start the Pz. IV. in my stash.I tried the putty method last summer after seeing the Plamo tutorial mentioned above. It was to hard for me to control rolling a consistently thin thread of putty. Then again the only epoxy putty I could get my hands on at my LHS was the Tamiya one, and that is quite sticky.
/Daniel
