OK, lets see how this one goes. This is one of the ICM re-issues of the old Revell figure kits. I bought it with the thought of trying to convert it into a Danish soldier c1864, but as that didn't seem so feasible on opening the box, I just decided to build it as is.
The sprue and destructions shot:
View attachment 323823View attachment 323822
Very cleanly moulded in medium hard grey plastic. The instruction sheet has a numbered parts guide on the other side. For some reason there are four choices of paved ground for the base.
I've got on and constructed it ready for painting:
It all went together very well, with only a minute amount of filler needed. I didn't particularly like the way the cuffs were done in two parts, especially as cleaning them up destroyed quite a lot of the delicately inscribed decorative detail. I therefore ended up adding new cuff detail using lead foil - the fine lines will be painted on. Similarly some of the cap decoration was lost when removing the mould lines at the side, but I think that I should be able to remedy that with paint.
I don't think this is a particularly exciting figure and if anything it's a bit to modern for my taste, but I'll give it a go.
