Best to input you Christian name. Makes it mor friendly as most go by this.\ said:Hello folks...my first bit of input..duh duh duh duuuuhhhh!I use Vallejo Model air varnishes, Matt, Satin and Gloss. They all spray on brilliantly, especially the Satin and Matt, but I have found that you need to apply the thinners through the ol' airbrush.
Say three of four drops , well mixed and they seem to flow a little slicker.
They do take a while to cure properly, and I usually leave a gloss varnish about a week until I polish it up.
For Vallejo varnishes I use a .4 needle nozzle. With this combination I do no need to thin at all. If you thin gloss it will be less gloss. Not up with polishing varnish. But it maybe that a lacquer varnish may be better for your use.
