ISSUE 82-Floor brackets.
Issue 82 contains three transverse floor brackets each one of which differs,be careful to make sure that you araldite the three members correctly so do a dry run first,the only problem experienced was to open up one hole which was cast over and needed drilling out otherwise I am pleased to say there were no major obstacles to overcome.Before glueing the vertical longeron locators assemble the front bulkhead sliding the pre-glued floor/bulkhead assembly from the front and into the ends of the longerons.The photographs taken from the top and bottom below show how the assembly looks once into position.
