Issue 94 gives you the second set of centre section struts mentioned last week,I strongly advise you not to glue the struts together as shown in the instructions,by doing so means that the lower portions of the struts cannot be anchored easily as they need to be thread through the upper metal shroud,this will prohibit the shroud riding upwards to gain access !
Also it is suggested the side cowls be glued into place,once again by doing this at this stage will make the access to the control cables difficult.
Further investigation of the control run from the aileron pulley to the lower floor area confirms that the cable can be threaded aft of the spar,it threads between the spar and the ammo box itself,my worst fear was having to drill through the spar but this will not be necessary,work for the time being is frozen until we get more parts,this is not exactly helped by next weeks offering a stingy piece of cockpit coaming ! it is obvious that by doing this people cannot back out as Hachette have conveniently left the cowlng to issue 100,if we had the more difficult to make bits then we could have easily made the others,charging us £3.99 for a piece of rubber is a bit steep.
So we only have six more issues to go and still need-
Cowling,undercarriage bungee rubber,undercarriage struts,wing rib lacing,control cable material,decals.
What a drag to have to wait six weeks for these !
