ISSUE 97-UNDERCARRIAGE STRUTS
This issue contains one set of undercarriage struts,ie one side,unfortunately the struts are handed so we will have to wait until next week to fully complete this assembly,what can be done is firmly araldite the legs of the struts together,there will be a lot of weight on these so make sure you do a good job,to see what the model will look like standing on its undercarriage I have mocked it up by just resting the gear against the fuselage as seen here.
You will need to run a file around the axles that go into the brass tube,the tube runs between the undercarriage mini-aerofoil then through the ends,springing comes from four rubber o-rings attached to the tube and looped around the undercarriage bracket itself,this is called bungee springing and was used on most early WW.1 aeroplanes.
So hopefully next week she will be sitting on her wheels properly,here she is just resting on books,but it shows what the model will look like when assembled.
