This is the sea hurricane kit but I have a 1/48 hurricane MK IIC so I'm going to swap the bits out and turn it into a MK I so I can finally build Bader's hurricane
I've solved my problem with shallow panel lines after the excellent advice from you guys and talking to people at the show yesterdayView attachment 82821
Now what I have done is pre-shade it with a thin brush to limit the over spill and leave to dry , then I have dry brushed the panel lines and then brushed the rest with a little bit more paint on the brush but not as dry as with DB , you must DB the line once do not go back over the same area as this will cause the paint to pull leaving a mottled effect , after each coat you must leave it to dry completely and this won't take long as it's only thin layers going on
I was going to do more coats but I thing leaving it as in the pic it has left a rather good weathered look
This piece has had four coats
