Iwata airbrushes, which one?
djellis10
Hi Peeps. Can any iwata airbrush users recommend which model airbrush to get for broad spraying base coats (typically 1/35 scale projects) yet has good control for fine detail work. I have a budget of £100 to spend. Any help would be great!
Hello:
The Eclipse model, hands down. I've seen them in the US for as low as $99.00. make sure that you get the crown cap so the needle is protected! I also have the HC plus but its a little pricey-around $199.00 but produces very fine lines and has a backstop rest/nut that limits the trigger and paint flow. Its really overkill and clogs easily. The Eclipse has to be the best price to preformance ratio on the market. HTH-Jeff
