Hi
This is my latest Model - see the photos
as it progresses and moves along
This is the
Hasegawa N1K2-J George
1/48 Japanese WW2 Fighter Model
it uses Eduard Photoetch and Montex Masks for use
instead of the Kit Supplied Decals
try clicking on the picture
slideshow emerges
The Model uses Vector Resin engine , Fukuya Brass Aftermarket
20mm Barrels and Hollow Pitot tube ( not fitted yet )
The AeroDetail Book on the George Fighter was used to supply extra detail on the cockpit and other parts of the aircraft .
The reason for using the Montex Masks are that I will be able to weather over them , which you can't easily do with a fragile decal .
Another added bonus is that the Kit Supplied Decal for the Recognition
Stripes over the Tail is wrong , it should be White - not Red .
The Book 343 Kokutai -Genda's Blade by Henry Sakaida
also proves this fact - this is the aircraft at the top of the 4 examples
from the after market decal set in my pictures
I will keep this on longer than usual ,
as I am using my spare Photobucket account
The usual one is used for ebay selling
hopefully if you click on my slideshow you will see everything
regards
David
This is the
slideshow emerges
regards
David
