We have numerous light bulbs with pins and things and not your ordinary light bulb.
Most of these are now obtainable in LED format. For instance a 16w halogen G4 (the one with the pins) is available in LED 1 to 5 watt (5watt about 50w ordinary old bulb).
Advantages you use a minute amount of electricity, instead of a red hot bulb. It is virtually (5w) skin temperature plus they are said to be 30,000 hours etc.
I use the halogen pin ones for lighting my shelves showing my models. In these LED formats they do the warm white (3000 K approx) which gives a slight yellow. For the models I wanted a daylight and a number of manufacturers produce the LED in daylight for (6000 to 7000K). just changed to these day light types and the transportation is just perfect.
I also have the same photo lights giving day light conditions.
