Lights
Hi
Im not sure this is in the right place but i have bought a land rover defender toy. I want to make it into a police car. I have found this circuit on the internet but i want to put more than one LED in it. Is this possible? If yes please could you tell me how.
Thanks
I assume that is a flashing beacon circuit for the blue lights?
Adding more LEDs is fairly straight forward. Just reduce the resistor values to suit depending on how many more LEDs you want to add.
Resistors are cheap enough, so just buy a variety below the value in the circuit and experiment.
It s the 470 ohm resistors you want to change.
Try 220 ohm.
My electronics is a bit rusty so I'm sure someone will correct me if I'm wrong.:play_ball
