New from SMS Matho Models 4-5mm Photo-Etch Numbers 80007
Matho Models 4mm and 5mm Photo-Etch Numbers​
Matho Models 80007 is a detailed photo-etch sheet containing digits in two different heights. The sheet includes 4mm and 5mm numbers, providing two clearly defined sizes for adding precisely produced numerical details to scale modelling projects.
The photo-etch sheet has a thickness of 0.16mm and features extremely crisp, true-to-scale detail, including across the smallest numbers. The height of the digits is listed on the sheet, making it easy to identify and select the appropriate size when planning the required numerical arrangement.
4mm and 5mm Photo-Etched Digits​
This Matho Models accessory provides digits in both 4mm and 5mm heights. Having two sizes together on one photo-etch sheet gives you a useful choice when deciding which physical number height best suits the intended design. The clearly listed heights also make it straightforward to distinguish between the two sizes before selecting the required digits.
The 0.16mm sheet thickness combines with the precisely produced characters to provide finely detailed numbers. The photo-etch process delivers extremely crisp definition and true-to-scale detailing, giving each digit a clearly formed appearance even at these relatively small sizes.
Suitable for All Scales​
Matho Models specifies this photo-etch number sheet as suitable for all scales. This allows the fixed 4mm and 5mm digit heights to be selected according to the physical size required for an individual modelling project rather than restricting the sheet to one particular model scale.
With two clearly identified number heights, the sheet provides a practical way to maintain consistent digit sizing throughout a design. The combination of 4mm and 5mm characters, 0.16mm sheet thickness and extremely crisp, true-to-scale detailing makes Matho Models 80007 a precise photo-etched option when either of these two number sizes is required.
The post Matho Models 4-5mm Photo-Etch Numbers 80007 appeared first on Scale Model Shop.
