Microscale: Micro flat
I have some of this and would like to know
1 does or has anyone used it?
2 how you applied it ie: brush/airbrush?
3 did you apply it all over the kit or just on the decals?
4 Did it leave any residue
5 Was it any good?
I want to use it on the MH-60 that s nearly finished but obviously don't want to wreck it. Any help would be greatfully received.
I got the stuff Terry in case of a decal which was a bit flimsy. For ordinary fixing of a good decal micro set is the answer.
Do not use any of the Micros unless I get into difficulties. Usually coat in a matt finish varnish which seals every thing.
Thanks Laurie I am using Micro set and sol on this kit and it is really sitting the decals down well. I was just wondering more about the flat as it says it can either be put on a specific area or sprayed over the entire kit.
I would have thought just brush on the actual decal Terry. Perhaps try an experiment on an odd decal etc.
Be interested to find the result.
