Missing Instruction Manual
I recently went to a garage sale in east Texas and purchased a Premier Balsa Products 1/4 Scale Piper Cub Kit. Everything was there except the manual on how to build it. I have not been able to find a current listing for this company, but would definately appreciate a copy of some kind.
Hi,
Have you found an instruction manual yet. If not i have one of these kits part built,it is up at my mum and dads house.
I am going up on Monday to visit them and will drag it out.I am sure i also increased the size of the booklet to A4 size and copied it.
I can either photocopy it for you and post out at the postage cost or we have a fancy copier/scanner at work that will save it to a file which i could email to you, when i figure out how to do it.
Hope this is of help to you.
These kits are now very rare,they also did a scale tiger moth as well.
regards
Charlie
I visited the Loughborough MFC Swop Meet and came away with a Premier Piper Cub 1/4 scale kit. The box graphic mentions an 'instruction book with step by step assembly by numbers' which would have had a parts list.
Unfortunately Like Big bluebeast both instruction book and parts list are missing from the box which, as it is a complicated model, will make building this model 'interesting' to say the least.
If anyone has a set of instructions who would be prepared to copy them and post them to me I would be very grateful. Obviously I would pay for the said instruction book.
Hello all, I have just joined the forum to see what info is about on the premier balsa 1/4 cub before i start the build. I came across this listing. I have copied the instructions and parts list as the book was looking worn out.If anyone wants a copy let me know. will have to post as i scanned them in at high res and enlarged to A4 so i can read at work and it ended up about 1 1/2 gb so cant email.
In the mean time can you let me know how your getting on with the build as this is my 1st large project.
Thanks Dave
I now have a copy of the instructions for this model, I swopped the instructions for a scan of the wing plan, if anyone wants a copy please get in touch.
Hi Glider Guider, i am looking for instructions as well. Do you still have a copy and in what format - hard copy or electronic? Thanks.
Yes I still have the instructions in pdf format. I also have an instrument panel in jpg format that you may wish to use. I will attach them both here it as it may be of some use to others.
PM me your email if you can't get the attached files and I'll send them to you.
David
\ said:
Yes I still have the instructions in pdf format. I also have an instrument panel in jpg format that you may wish to use. I will attach them both here it as it may be of some use to others.PM me your email if you can't get the attached files and I'll send them to you.
David
Thanks very much for the instructions and instrument panel, both opened ok & will be very useful. Now the fun begins.
Happy flying,
aeromil
Ouch! I hate it when things like that happens...
