This will be the basis for my next Build-A-Long something a bit different to the norm a Russian Jet fighter aircraft the Sukhoi SU-11 that was kitted by Aerographics,a glance at the contents showed that no wood is provided for the tail surfaces for some odd reason ? this is no real problem it just seems a bit cheapskate for a kit that is not cheap anyway.
Once I commenced to cut out the printwood I immediately hit a problem,the shapes are printed on paper that is stuck to the wood by very poor adhesion,thus when you take a knife to them the designs slide around with the pressure of the blade ! not good so cutting was halted and the paper re-glued properly to the balsa stock and they are currently drying out overnight so they can be attacked again with the print firmly stuck down into position,I will leave the paper stuck down as it holds the grain of the balsa together.
These models were powered by Rapier rocket motors which are no longer available so the Sukhoi SU-11 will probably be used as a chuck or even a catapult glider,we will see how things go.
The kit contents,very basic but adequate to build a simple model,grey tissue paper one choice of markings but box says otherwise,stripwood good quality,printwood patterns as described above.
A bit of lite ply is included.
The peeling paper former patterns,looks like poor self adhesive that has lost its grip,now fixed with aliphatic adhesive.
Patterns held down under weight to stop curling of the wood whilst drying.
I will build the wings first on this one,they are very simple structures with only a few parts to them.
![Sukhoi Su-11 [LIMITED to 500px].jpg Sukhoi Su-11 [LIMITED to 500px].jpg](https://www.scalemodelling.co.uk/data/attachments/113/113999-da3bfcf0f8b6df61ccd7760fd58c5fdd.jpg?hash=tEKpMzYeVM)
