Modelling Putty
Here's a real dumb newbie question...
What consistency should I expect modelling putty to be?
I bought my first ever tube of putty (Italieri) and it comes out like paint rather than a mouldable putty like I was expecting. Fine for brushing into gappy seams, but not much else.
Is it a duff tube or past its shelf life? Or is it meant to be like this?
Any pointers appreciated.....
:hmmm:
Sounds like it could be past it's shelf life if it's not setting, I use Squadron green putty, I used it the other day first time in ages and it worked fine, comes out like paste dries quite quick ready for sanding.
Thanks John - confirms my suspicions. I'll head for the Squadron shelf next time.
\ said:
Here's a real dumb newbie question...What consistency should I expect modelling putty to be?
:hmmm:
I have been experimenting and trying to find a filler that works for me. I have had some success with Squadron putty and thinning it with acetone for finer fills.
I have had limited success with Microbubbles and super glue.
Squadron putty every time,the brand market leader,it sounds as if you have a faulty tube there minus some important part of the formulae,send it back to the manufacturers for attention,they need to know.
:hmmm:
just getting back into modeling and i puttied the seams and sanded them but i think i made a mess of my model.
could someone point me to a sanding tutorial? i scratched the surface of my model something awful while sanding it after puttying. i have 600-1500 grit and i bought a polishing stick (cuticle polisher) for finer areas.
after painting, i can still see my sloppy putty job underneath.
should i have wet the sandpaper? any tips are appreciated!! thanks so much.
