I'm guessing sci-fi is the right section for this one.
First figure model i've made and thankfully don't have to worry over accurate skin tones as this kit is the Iron Man suit from the movie of the same name, this one being the MkIII suit, (the first gold and red one).
The kit is very nice, quite a rigid styrene, glues well with ordinary cement, sharply moulded detail, a few visible join lines that needed a skim of filler and some sanding but almost a snap fit assembly it was so easy.
The base is primed in rust shades and will have metallic and paint overcoats with weathering to show rust through.
The figure is primed in grey, there are a couple of areas needing further filler attention just as always then another coat of primer to cover those areas.
Progress pics so far.
