More DeAgostini probelms
Just completed collecting all 75 issues, have put it all together and started setting up the servos.
The prolem I have is that will I pull the trigger the servo mores forward and applies the brake rather than opening the carb.
Similar problem with steering, turning the controls left turns the car right and visa versa.
Any ideas?
All the servo cables can only fit one way adn according to the instructions the servos are the right way round.
if you look on the bottom , or back of the controller there should be 2 very small switches, now have a good look because they might not be that easy to see. they are servo reversing switches, find them and flick them the opposite way they are just now, this should cure your problem.
You will have them .
any more problems just post in here.
Adz..
Ooohh.. Jealous.... I am up to issue 42 now - just got all 4 wheels. Mine should be finished around Xmas. What colour did you do your bodyshell in the end?
