Mr. Masking Sol Kai
has any body used the product mr. masking sol kai?
designed to be painted over the clear parts, and once dried provides a protective barrier for painting.
once painting is done is easily removed using the tip of a knife, a needle or tooth pick.
along the same lines as using masking tape but apperas to me to be a little easier in the effort department.
has anyone used the product? and what are your opinons about it?
Humbrol also do a liquid masking fluid for clear parts called Maskol. Good kit.
ive used the mr masking sol, and though it works, it takes several applications to get it thick enough to cleanly trim it. too thin and doesnt matter how sharp the knife is it pulls the coating off as you try to trim it.
