Scale - 1:1
OK strictly speaking, not a 'build', more a strip and rebuild and strictly speaking not a model, however.
Bike looks like this, Mini Ducati 916 clone, every 17 yr olds drooling fantasy, (yes i'm trying to recapture my misspent youth in a haze of two stroke fumes, especially as i couldn't afford one of these when I was younger)
Mine currently is stripped to the frame / engine / running gear and was CAKED is crud, you would not believe, it had been the property of a 17 yr old with the typical mechanical sympathy of someone that age.
So a good half day with buckets of WD40 and Gunk and a good hose down then blow off with an airline and we have, ta-da
Yes, theres a bike under the gunge, looks pretty good and I know it runs well, some light surface corrosion to the alloy parts but with the rubbish off not bad.
Plastics to de-crud, wheels to prep and re-spray, then a host of new bits, Fork seals, tyres, brake pads, fluids etc etc
