Hi guys,
I am having problems when airbrushing as the finish turns out to be like a sandpaper texture. I am using dual action airbrush revell white paint thinned with revell thinner 1:1 ratio. I have sanded the model with 600 grit sandpaper and washed it in a soapy water. Then applied revell white primer (probably a mistake to buy white primer when paint will be white as well). Had problems seeing what is covered. I have tried 10-20 psi and different distances from the model. I have tried to spray humbrol in matt colour on some pieces and it looked quite fine with matt finish but still smooth whereas I have also tried revell matt colour which turned out to have sandpaper's texture. I would really appreciate if someone could tell me what I doing wrong? And if you sprayed revell enamel please share your settings. Thank you.
