Nitro Monster Truck
Hi, i'm new. I was wondering if anyone knows when you get the Remote Control in the nitro monster truck series. Do you have to order it or does it come on the last issue?
there is someone on here who is making it, have a look in the automobiles section. as far as i can remember, you dont get it.
you have to buy one yourself.
welcome to the scale-models, i cant assure you there will be someone on here you will always be able to help you!
Richard .W
Not sure if it comes with the mag or not but i see no reason why fitting a normal 2 channel one wont work!
A 2 channel truck would need:
Transmitter: thing you hold with levers and controls
Reciever: this recieves the signals from the transmitter and then tells the servos what to do
Servos: two small black boxes with motors inside that are used to actually move the steering rods or fuel/air mix on the engine
Crystals: you need two of these in the same freq. one in the transmitter and one in the reciever.
The whole lot shouldnt cost you any more than £50 brand new (try Acoms) or around £25ish on ebay.
You collect the tokens from the issues and send them off with the money to get it from hachette,as you should of got a little leaflet with the first issue to tell you how you get it.
