Not a tutorial, just a tip
Hi. im not sure how well this will work with enamals but if your using Tamiya water based 'synthetic' acrylics once used can easily be washed out with hot soapy water (remember to take the plastic seal in the lid out with a screw-driver or something to clean under it. it easily pops back into position.
Once clean and dry with the lable pealed off you have a brand-new pot witch you can mix colours in without them setting....etc
like i said, just a tip. One which people already probably do but hey.
I use games workshop which are 99% the same, ill give that a go!
