Has anyone ever had an ESC kill a receiver?
Is there a way to test the BEC?
Ive been having problems for a couple of weeks now, no power, low power, car will only run with it off the ground and upside down(true). Had a receiver replaced under warranty as it lost the throttle channel and now last night it was glitching madly, would throttle on and there would be a delay to drive, throttle off and a delay to brake.
Batteries appear to be dumping when they are not.....
is it possible that my ESC is killing receivers?
only running a 19 spec or 27 stock motor in a xxx-s g with sanwa gemini radio
