As I have mentioned else where, I now try to avoid airbrushing when I can by using spray cans, for example primer (Halfords) and, when needed, Tamiya Synthetic Lacquer (TS range). Nothing to do after applying the paint and no fiddling with bits. And no blockages nor uneven spray.\ said:A bit pointless as its now fixed, but i was going with nozzle, i tried cleaning mine with a reamer and couldnt understand why no paint was coming through, needle pushed through all ok - until i took it along to SMW 2015 and the good guys at Airbrush heaven spotted - a) needle was bent and b) i had opened up the nozzle so when pulling the needle back it was still blocking the tip!!. Fantastic things when they work but nightmares when they dont. I liken it to playing golf, you can hit a perfect ball, set back up again and whump, sideways into a bush - but you have done nothing different !!!!, stupid game i gave up !
