A brief interlude from painting and weathering my Dragon Tiger, I was a little wary of trying out a new technique on an expensive kit, so I dragged a lost-cause T-62 from the shelf of shame! I lost interest in this build after a real "meh" paint job, that just wasn't doing it for me. So, I gave it a blast with the old rattle can primer and decided to put Michael Rinaldi's techniques to the test. However, as it was an experiment, I thought Id paint the green in the Grumpa method, using cheap hobby shop acrylics, applied very thin with a brush. My first impressions are that the painting works perfectly for tanks, at least, you'd struggle with some aircraft builds, but for tanks, it works!
This was after 3 coats, and remember, there is a full paint job under the primer, so some detail is lost with this one. But on a fresh surface, it'll be fine.
After the base coat was good (about 5-6 coats) I started on the oil rendering. I bought about 6 tubes of Abteilung 502 oils from John, despite already having all of the colours in "Cotman" oils - this because both Rinaldi and others emphasise that these oils are created for this use, I was a bit sceptical, but this turned out to be so true! - they are beautifully creamy and smooth, perfect for brushing out until nearly invisible, which is key to success in this process.
So I spent 2 days tinkering with it until I figured I had done enough, and it was fresh in my head before tackling the Tiger tomorrow.
Needless to say I'm hooked! The last shot has had a fair bit of pigment action, but the whole thing has been done with brushes and despite the loss of surface detail caused by not being arsed to strip it, I feel it has served a really valuable purpose.
As soon as my pension comes in this month, I'm gonna buy a few more of those Abteilung oils, only need about 5 more. the potential appears huge to me.
And a tip of my cap to Grumpa, his painting technique is really flexible, controllable and, most of all, cheap as chips!
Edit to add this:
Edit to add this:
