Paint removal .
Alan 45
I started a 1/72 harrier on Friday and really messed up the paint job on so I was wondering what household cleaners might fetch it off but not damage the kit I have heard that oven cleaner works but the only stuff I have might melt the plastic
Any help is very much appreciated :)
what paint have you used?
mr muscle oven cleaner is great for removing acrylics................brake fluid is good for rattle cans
just be aware of all the H&S considerations with whatever you use
Cheers folks I am using acrylics and at the moment it is in this doctor power stuff that says removes anything I suppose I will find out by morning if it has worked if not I'll try your suggestions lads thanks :)
For acrylics, I use this but too be honest I don't need to use it too often lately:)
Alan what sort of acrylics as they are some very different to each other.
If it is Vallejo then a Friday effort will be removed by Vallejo Airbrush Cleaner with out any effect what so ever except for messy fingers.
Thanks for the advice guys it worked a treat :) I couldn't get the fairy one but tried cillet bang and that worked well it took a bit more rubbing but done the job :) I should have this harrier finished today so I'll post pics later :)
Thanks again
