Canopies and other clear parts are usually masked and glued to the fuselage before the whole model is primed, camouflage* colour coated, and varnished. This means of course that all parts, including the metal framework of canopies, will be given five coats (one primer, two colour coats, two varnishes). This will produce a certain thickness of paint. (I use Vallejo Model Air.)
The metal bars on a 1/72 model are very narrow. Is there a risk that this thickness of paint (supported by such a narrow part) will be fragile and get knocked off with wear? If so, miss out the primer by using an overall mask on the canopy? Or would the varnish coats protect it?
*I have only recently discovered that "camouflage has a "u" in it! Wikipedia says "it is...either by making objects or animals hard to see (crypsis), or by disguising them as something else (mimesis). Fancy that! (I reckon politicians are into mimesis!)
