I'm building my first tank in ages and eager to begin with this fun hobby again. I bought some Tamiya acryllic paint and thinner (not Tamiyas) to paint it in a winter camo theme and I just finished with the base coating. This is where I want some advice, I tried to take a picture that shows the problem but it wasn't so successful.
As you can see on the plating there is some paint that has been collected in a small drop, and the paint also is unevenly spreaded (you can see the brushstrokes almost on all flat sides).
What should I do to counter this? I will probably buy a very fine sandpaper to sand this down but what can I do to stop this on the next layer? I don't know the ratings I should use with the paint and thinner, I think I have used too little thinner.
Thanks in advance!
Thanks in advance!
