Right. This is my first attempt at a Tamiya tank. When I was young I could only really afford Airfix, which were a smaller scale & less detailed.
So far this has been a learning curve...which is exactly how I'd intended it. I've needed to buy loads of 'stuff' as I go so the process is proving a lot slower than I'd imagined, especially with all the bloomin' filling!
Lessons learned:
1) My eyesight is pretty awful close up, so stronger glasses & a magnifying glass have been essential!
2) My fingers are much fatter than when I was 13!
3) My hands shake much more than I thought :smiling3:
4) I'd never bothered with filler 35 years ago...if it even existed!
5) Some acrylic paints really don't cover well...good old Humbrol worked much better!
With those caveats in mind. Here goes...
This is the construction shed:
My first attempt at sanding filler. Luckily I started on the underside, quickly realising that the wet & dry I had intended to use was far too coarse. Off to the i-net for supplies!
Construction of the upper & lower hull with some filling done. I'm going to put the tools etc on the hull after spraying. This could be wrong, but I'm going to try it anyway :smiling:
(Mostly) complete turret filled & ready for sanding. The Cupola I'm not quite sure what to do with as I've 'blacked out' the commanders 'port holes'. The inside of the turret has been brush painted with Ivory requiring about 4 coats to cover the grey plastic. I'm considering leaving one of the side doors open, hence the work on the interior, but if it doesn't seem to work with what I have in mind, the turret side doors will be closed meaning I've wasted several hours...but not to worry.
Wheels & tyres done. These took ages & tested my not so steady hand. Initially I painted the tyres on the sprue, but after removing them & gluing the halves together realised that indeed it is much easier to put them on narrow sticks (I used the wooden straws from a couple of those room diffusers)
Lastly, for the moment. After having problems fitting the upper & lower hull together. I managed to get everything to seat comfortably without obstructing the muffler assembly.
View attachment 318217View attachment 318218
This process left a gap around the front drive wheel which I filled & sanded as best I could in the restricted space
I'll update this as I go...
Lessons learned:
