papa 695's HMS Illustrious
papa 695
Staff member
I've wanted to do this for a while now so now I've got some glue I'm starting this. Got some figures on order and going to get some more aircraft for it, it's going to be a small ( ish ) diorama
Fantastic choice!
Your "water" effects are always very nice, so I'm sure this one will be terrific ;)
I built this 18 months ago, I must have had a damaged kit as it took 2 tubes of Zap- a Gap to get the hull to even look straight, but I'm sure you will do it more justice than I ever did. So I'll be sitting on the dock of the bay watching this ship sail away :)
Adrian
Very nice Ian.
To help on scale Ian it may be an idea to put a pencil in the photos. It will just show your skills as this is a small scale model. (or is it large scale confusing ) ?
Look forward to seeing how this turns out, mine was so warped and ill fitting I gave up on it and binned it!
Hi Steve the sides are a little warped but they don't look too bad but still plenty of work to do before I need to worry too much about that
i'm guessing this kit is finished now but can't you put the hull or the warped pieces in boiling hot water then clamp them to a flat sheet of plywood or something to get them back in shape ???
Hi Dave. It's not finished yet just put on hold until I get some group builds out the way,
Thanks for the tip but I don't think it's that bad, but will see when I get to that part of the build
i don't know if it works as i have not tried it before but i have seen and heard people using it. i know it works on bending wood coz i have done it
The warps in mine were inconsistent and in different directions so I would not have known where to start, I will build this one in the future.
