Plaster is very usefull in all areas of modeling from filling pieces to give them weight.or making scenery or anything.so get your plaster and a bowl.rule of thumb your water anf plaster will double when mixed.fluff your plaster up with your hand and start sifting it into the water don't rush just keep adding round the bowl.when you see a few islands of plaster on the water stop adding the plaster.leave it to soak for five minutes then use your hand to mix.no lumps no bubbles like whipped cream so you can pour it easily.it's also a stronger mix for your projects.easy peasy
