Pete's Airfix 1/48 Jackal
stillp
I bought this at the St Ives show a few weeks ago. Having built the Warrior from the same series I'm looking forward to this, so on with the photos!
The kit originally contained 8 RAF Regiment figures, but they'd been taken out, hence the bargain price. Just as well really, I'm not good at figures.
The sprues:
There's some very nice moulded detail:
More later I hope!
Another great choice for the GB Pete. Looks a good kit. A few years back we used to see these all the time bombing around the streets of Plymouth on their road tests. Good luck with the build.
A couple of axles/ suspension units built:
I might wish later that I'd painted them before assembly...
The instructions say to attach the wheels and tyres then fit the axles to the chassis, but I think I'll skip those steps for now - the tyes will be easier to paint if they go on last, and that suspension looks a bit fragile so better to add it as late as possible.
Thanks for watching.
Whoops! Ignore that bit about fitting the axles later, they can't be fitted after the chassis/lower hull is fitted to the upper bit! :disappointed2:
Edit: One of them can!
I'm not sure if I need to do a bit of painting before I add any more. Any thought folks?
Well, if the rubblemeister recommends paint, then paint there shall be!
Tamiya XF59 Desert Yellow again. Much of it will be removed when cleaning up the parts after removal.
Edit - PAINT!!
A small mistake by the Airfix instruction writers:
It's a real struggle to find part 6D... there are only three sprues!
Ah, here it is on sprue B:
And fitted:
The doors open and close, and those racks/shelves on the right can pivot through 90 degrees. They could really do with some crapintheback.
More soon, I hope.
The front end is on, as well as the front doors:
There are 6 decals for the IP, which settled down really well with a dose of Microsol:
Next up is the armament.
