As we seem to have had a few photo manipulations recently I thought I would pull a few out of my collection for you to have a look at. Explanations as follows:
1) Just a bit of a play around with the car. Two copied layers, one changed to B&W and blurred laid over the top of the original and then carefully erased away.
2) This doesn't look too exciting but I carefully removed a large advertising hoarding from behind the train before changing to B&W.
3) This is actuall a statue in Treviso, Italy. I got Annette to stand next to it and took a shot of her and then the statue so that the light was in exactly the same attitude for both. I then cropped her eyes from her portrait and resized & superimposed onto the statue.
4) This is a shot of my Cossack model on the pond with an internal picture from a Heinkel found on the net. Unfortunately the Heinkel shot was not very good but I enjoyed playing around with it.
5) This is two shots taken of one of ourt engine crankcases. The first was with the door fitted and the second was without it. I copied the closed one on top of the open one and erased away the door to reveal the con-rods in side.
6) Two layers again, one blurred and sepia tones and then erased from over the original.
7) Same process as the engine crankcase.
8) Same process as the bike. I quite like this technique!!
