I'm about to use pigments for the first time, I've checked out some vids on youtube which seem a bit unclear, Just need to ask when applying pigments do you just directly brush it on to the surface or is anything applied before hand. Also if you don't need to apply anything does it just stick to the surface by itself . Should I apply grass, tufts and leaves etc first or should I apply the pigment first. Cheers
