Okay, I've been a 20% Castor man from day one. The reason? Early synthetics were junk - this is 1970's - so never touched 'em since.
Couple of years ago I started running a couple of big motors. Super Tigre 3000, 30cc, and a G20/23, 23 cc and used the recommended fuel of 12% total oil content comprising 6% Castor and 6% Synthetic. Works fine no prob's. Puzzlingly (is that a word?) I have a Moki 30cc and the manual states 15 to 20% oil, Castor only!
Lately been running an ASP 91 four stroke on 20% Castor. The motor seemed okay if a little tempremental. Tonight I used a 10% Castor, 10% Synthetic mix and the motor is quite obviously happier on it. Frankly I'm amazed. Plus the gunk is easier to clean off the model!
So what are you peeps using in your run of the mill engines?
Please post what you like about this particular fuel.
