Problem with decal silvering:used Vallejo Decal Fix
Oh nooooooooo Laurie that's your theory blown out the water by the man with the lab coat. Here I was thinking you'd stumbled across the miracle cure for decal silvering guess now the jury's out.
But just for the hell of it I'll get some anyways and I can always cuss and curse you if it doesn't work. :)
Actually so far I have tried two decals Hasawega and Revell Steve. Both on varnished and matt paint.
With the Decal medium added next time. I will try as many decals possible until my patience is tried.
At the moment I am looking on the optimistic side but like all things the proof is in the eating.
But the interesting thing here is that the two Micros have failed. What is interesting is that Decal Fix has
worked and the seeming fact , to be proved, that you can apply decals on matt paint with out silvering.
laurie
It's also worth remembering that different brand solutions vary considerably in strength. Some decals will be destroyed by an average solution (like Microsol) whilst others will be impervious to it.
I always experiment with an unwanted decal before applying any solution to the decals on a model. It's easy to dilute a solution if it is too strong. If it doesn't work on a particular set of decals, then you'll need to find a stronger one.
I tend to take Microsol, which I generally use, as a benchmark to estimate other solutions. I use the red (heavy) Daco softener for really recalcitrant decals but you need to be careful with it! It is definitely a stronger solution than Microsol. I've also got some Mr Mark Softener which seems (unscientifically) stronger than Microsol whilst not quite as fierce as the Daco product. Daco to produce three different strengths but I've only used the strongest.
Another trick is to use really hot (as hot as you can stand) water to remove the decals from the backing. The hot water will soften the decals somewhat before you add any solutions. You can also use a softener (like Microsol) as a setting solution, but you need to work quickly as the average decal will start softening and be risky to move in about 15-20 seconds!
After that a hair dryer and careful application of pressure can work wonders after the decals are applied. Again you need to be careful to soften the decal and not melt the model :)
I have now got hold of both Vallejo Decal Fixer and Decal Medium. Vallejo say use Decal medium
as the base before applying the decal. Fixer after. There are an number of tutorials which seem to
mix up these ie vice versa. Vallejo instructions. http://www.acrylicosvallejo.com/en_US/applying-decals/blog/1/35
To recap I had trouble with all the Revell (British Decals) on the Hasewaga Apache. I had sprayed two coat of
Humbrol Clear. Then applied the decals with just water. Some silvering but the main problem was the clear part
of the decal stood out and looked not very nice. Applied Vallejo Decal Fix and the clear decal disappeared. The
decal fix area dried matt.
The white rivets are not silvered bits they have just caught the light.
I then tried the medium and fixer on just the matt finish of the Vallejo paint. This was as per the Vallejo instructions above.
I used about 6 different manufacturers decals. Out of the 6 there were two with minor silvering which I left with out trying
to rectify. The results especially considering that the decals were applied direct to the paint with out varnishing are good.
75036 is partly silvered on the 6. Bottom of the R on R9125. What may look silvered elsewhere is the photo lights giving glare.
Other than those mentioned all turned out perfectly. But edges of the clear decals were seen if looked at very closely.
However I think on balance that I will still coat with two coats of Humbrol Clear then use the method the Vallejo instructions
above detail. The finish I achieved on the first two photos above were as good as perfect.
For small bits and pieces for which applying two coats of Humbrol Clear would be a chore the Vallejo way would be perfect.
Not saying this is better or worse in most circumstances than the Micros. In my case with the Revell Decals the Micros did
not work the Vallejo did. And so the Vallejo product, for me, is another thing on the shelf in case.
View attachment 136568 View attachment 136569
View attachment 136570 View attachment 136571
Thanks for this post matey
