Re-Building the Red Baron
Barry I have to send you aheart felt thank you for the thread article on building the Red Baron, my tri-plane has sat sadly silent gathering dust since i bought it as there are so many mistakes and when I got it I was just a plain (plane) novice at this but now with your help through this tutorial I think I can now set about and do a re-build with some degree of confidence????? or I certainly hope I can, it does mean however tearing the plane apart and staring all over again but I'm prepared to dot that especailly when one wing has two different spar?? cross frames on it, I'm only hoping that I use white glue on the wings so I can drop them in water to pull them apart as for the air frame well the glue should be suficently brittle enough to be pulled apart easierly but carefully. Again BArry thanks for this tuturial and I will post a photo of the plane when it's finished but don't expect it real soon hey. :thumbs-up
Desert Rat
You know even after paying $1,100 Australian I was prepared to throww this at the time piece of shit ( excuse my language) project in the bin as it was so bad BUT who in thier right mind would chuck out $1100.
