Hello all, been rather busy of late to add much to the forum other than checking in daily to see what is happening. As is often the case a period of neglect has causes a failure in one of my Transmitters
hno: This one is an original Futaba Attack-R Model Ref FP-T2NBR dating from the mid '80's. A twin stick basic 27Mhz AM radio set which has the added advantage that the cotntrol modules can be roated through 90 degrees. This I have done and use in Tank driving mode for my American Pusher Tug "Red Hamish IV". Sadly I was daft enough to leave in a set of Alkaline batteries over the winter months, and yes you've guessed it, they leaked. The contacts have been cleaned but still the Tx is dead :angel: Has it got to go to heaven? I had problems with it later on in the last sailing season when the Aerial seemed to be loose. Does anyone know of somewhere the Tx could be sent to for refurbishment? As you'll know a faithful friend deserves better attention, I promise to look after it better in furture . Any suggestions would be greatly appreciated.
cheers
cheers
