Revell 1:24 Unimog Rallye.
\ said:
awesome.....been after one of those for ages
Hi Paul, Sorry awesome is not a word I would use on this kit, been pulling my air out a few times with it.. :( :( :( :(.
What is the issue with this kit??o_O
Different look forward to seeing this one John. What problems are you having with it ?
\ said:
nice to see some think a bit diffidence and looks nice, ;)
Thanks Monica, I hope it does turn out looking nice LOL.
the not the quality of the kit that appeals.....ive already got an unbuildable Revell Mog in the stash that one day will end up as a bashed up 'technical;......its the subject mater...im a big fan of the Dakar
Hi Gavin, Ian, some of the issues im having with this build are....
No locating pins/lugs for front springs need to guess the position for them & hope front axle will locate correctly.
Spare wheel & carrier supplied, but spare wheel not to be used as no Tyre for it.
Bushes fitted inside of wheels to allow wheels to rotate to loose, & wheels are then floppy & look ready to fall off.
Nice big Chunky tyres which the wheels just Fall through so tyres will not stay on wheels,
Cab glazing is only the windscreen & door 1/4 windows.
Front axle tie rod fouls bottom of engine & stops the engine sitting on front mounting.
Rear axle tie rod had to be removed to allow fitting of rear anti-roll bar.
I am sure there will be more issues the further the build goes on... :( :( :( :( .
John.
OUCH!!:confused:
Makes you wonder how did it (the model) make it to production??o_O
That is down right infuriating, when it becomes a nightmare to build!!:mad:
Good luck and "keep on truckin'"!!:rolleyes:
\ said:
OUCH!!:confused:
Hi Gavin, have come close to binning it a few times LOL..
Working on the cab & rear bodywork now & things are going along a bit better with these :) .
Hoping it will look good when finished, & will make up for all the Frustration it as caused me LOL...
John.
