Revell 1\48 Eurofighter Typhoon twin seater
peterairfix
Not my usual type of kit but I thought I would give a go.
First of all is to get rid of the horrible moulded seat belts and replace them with something better so I got myself some Eduard belt set.
And here's the results with the finished along side the unfinished oneView attachment 322940View attachment 322941
Time to revive this build.
When I retrieved this from the stash I have found out I did a bit more than I thought I did so I have two seats finished one IP done but with a dodgy decal two cockpit tubs started and I brought a front cockpit set for the forward tub as I have been unable to find a two seater set20190820_080907.jpg20190820_080916.jpg20190820_080923.jpg20190820_080933.jpg
Hi Peter
Amazing improvement with the aftermarket seat belts. Certainly worth continuing with.
All PE fitted in the front cockpit unfortunately I can't find any for the rear tub so its going to look rather bare.20190820_172813.jpg20190820_172824.jpg20190820_173507.jpg20190820_173518.jpg20190820_173743.jpg20190820_091717.jpg
Some more work done today some nice ejected pin marks to be sorted on the tail and the cockpit tubs fitted in nicely and the two fuselage sides fitted together nicely with no problems and lined up good with hardly any sanding needed.
And using my usual type of weight for the nose20190820_182053.jpg20190820_182019.jpg20190821_133258.jpg20190821_133222.jpg20190821_132404.jpg
Undercarriage bays started and installed in the lower wing also includes the air intake as well.20190821_191213.jpg20190821_192118.jpg
