Well I've had a spare bit of time today so thought this could do with some more work
Trial fit of bodyshell, what is it like?
Well it doesn't fit that's for sure, had to trim the rear internal frame by 2mm, ended up popping the dashboard out, looks like that will have to be placed in & secured after shell fitted & before screen.
Also the side exhausts don't line up properly no matter how I teak them so they're getting cut off the chassis and will just have the visible ends fitted into exits below doors.
All this leads to me deciding this kit will have the shell & chassis permanently fixed together.
Can tell this is an older kit than the C6R, detail is much poorer, things like vents/intakes are just moulded rather than cut out and I'm not trying to do them !
Anyway
Noisy end, pity it'll be hidden
Cabin, with "floating" dash
Chassis with exhausts off
Dry fit of chassis to body
More to follow, body has had one coat of yellow so far over white primer, will give it a nib and second coat later
