Russian Kilo submarine
very nice, was it pre-built or have you made it?
..if so what a brilliant spray job you have done!!!
let us know how the test dives go. get a video up if pos!
Nice sub Andrew
How is the "big" sub coming along?
Will catch up with you on Sunday
Alan
Hi Andrew, that looks rather nice all painted up. Are those draft markings dry transfer or stick on? Yes let us know how the ballasting comes along. Kilo's love to roll so keep centre of gravity as low as possible and centre of buoyancy high. As it only has a small lower rudder, you can help the turning radius by moving the CG futher back, if your running her in a small pond. I always find painting and ballasting the most satisfying parts of a build. How controlable is the gas ballast system? Can you release small amounts of gas at a time to control your depth; do you have to trim it so that it is at neutral buoyancy with the ballast tank full of water?
Kilo and build and RCABS vid
Hi guys
Here's a link to the build of this kit. The first one by Dave Merriman.
http://www.subpirates.com/viewtopic.php?t=32
And here's a video incase you haven't already seen it, of a Washington with the same WTC and ballast system by Dave Welch. It handles very well!
http://www.sneill.com/wtc/wtc.wmv
Sorry to drop in, but these might answer some questions for you guys if you haven't seen them before.
Jason
Hi guysHere's a link to the build of this kit. The first one by Dave Merriman.
Jason
Jason, Andrews got the larger SWM1/96 Kilo there, still the Trumpeter Kilo that Dave's converting is rather nice. What exact is your avatar of? :thinking:
I've seen it in various guises in the different forums we frequent!
Many thanks for the kind words guys - especially about the painting. If you could see some of my previous efforts you would know why I appreciate that so much! There's obviously a lot to be said for Halford's acrylic spray. The lining, depth marks and flag are from http://www.modelflags.com/cgi-bin/webc.cgi/home.html. Ordered via the internet and received 48 hrs later - couldn't get better service. The kit was bought on e-bay and had been started but had the odd part was missing so some fabrication was called for. The manufacturer is Small World Models http://home.san.rr.com/swm/ and is to 1/96th scale. In my opinion this is a super moulding with very clean hull markings. Goes together well with not too much effort.
As Mankster says the ballasting and test dives will take a little care to get it right. My earlier attempt at a Kilo (not an SWM kit) certainly rolled - a great deal! I don't think this one will be as bad as the drive battery is very low in the hull and the topside weight is a great deal less. I think it will be possible to only blow part of the ballast as the valve control is proportional - time will tell! See picture.
Meanwhile the Typhoon is languishing again with the front dive plane retract system in bits as the micro switches used to limit the travel are playing up. One of these days I'll get it all to work right - and then I'll be wondering what to do with my spare time! Almost forgot - I've got one of Norbert Bruggen's UB10s to get started on next.
Jason, . What exact is your avatar of? :thinking: I've seen it in various guises in the different forums we frequent!
Sorry I was out on the Kilo. Dave (D&E Miniatures) makes so many kits it's hard to keep up. Wrong seller. I'm a dill!:hipno:
Re the avatar- It's the magpie I put on some of my boats "Magpie Yachts". That actual one is a photo cut out of a figure that drives my ski boat.
See pic
After several days of testing in the bath I think I'm getting there! As Mankster hinted it rolled on its side on the first immersion and even when propped upright was also sitting far too high in the water. The solution was to gradually add pieces of lead sheet below the WTC and in the bow and stern until it sat vertical and a bit lower. There was a problem in finding an adaptor to connect the airbrush propellant can to the tyre valve on the gas tank but SubTech http://www.rcmodelsubs.com/acatalog/sitemap.html came up trumps with a supply can adapter. Ordered it and received it in 48 hours!
Another challenge came on the next test when the thing proved quite happy to submerge - but wouldn't blow its tanks. Two days later and after much fiddling with the valve timing it's now working fine I'm glad to say. Submerges and pops back up quite happily. Now I'm about to fix the ballast in permanently and do some more tests to ensure 100% integrity before venturing to our pond with it. Pictures will follow.
As an interesting interlude I've also spent 2 mornings ballasting out a Sheerline Akula belonging to a friend. It works too now! Let's just hope the first sea trials of both subs aren't too eventful.
kilo
Hi Andy, like the new boat, how many kilo,s have you got now, i got your email, have you started ub1 yet, i got a type 2 sheerline, very nice kit, regards Pete
The current submarine fleet consists of:
Engel Typhoon
North Seas Fleet Kilo
Small World Models Kilo
Sheerline Trafalgar class
Krick U25
R&R Resolution (2) 1 being the earlier 'short hull' version and the other the longer hull still in kit form
Norbert Bruggen UB1 (the next one to be started)
Robbe Seawolf
Plus a couple of 'targets' suitable for the days when the pond level is too low for subs!
As promised a brief video of the Kilo tests taken this afternoon in the bath. Please excuse the shaky hands - difficult to hold the camera and transmitter at the same time! Also this is the first time I've tried to use the video function on my Pentax Optio 4S. Still - you can see that the Kilo submerges and surfaces OK. Got to replace the handmade front planes with the proper ones that have just arrived from Dave Manley at Small World Models. The next thing will be to test it in the pond on Sunday.
http://smg.photobucket.com/albums/v394/ajg141/?action=view&current=SWMKilotanktest003.flv]
[/url]
The link to the video of the first tank test:
Apologies for the quality - I've not used the video function on my Pentax Optio 4S before - and it was also a bit difficult to use the camera and transmitter at the same time. Still the sub does what it is meant to do - submerge and surface. Still got to replace the scratch built front dive planes with the proper wants that arrived from Dave Manley at Small World Models this week - and a bit more ballast adjustment.
Sweet! I have adjust my cam thing to only just depress the schrader valve slightly at full throw, so she comes up very slowly with very litlle wasted gas. Just push the trim up if I want a rapid rise.
Smart
Hello all, Andrew this is looking very smart. The kids loved the video of it sinking and popping back up. Can't wait to see it happening in real life.
cheers
